In the Repeated Measures Degradation platform, the Data and Initial Model Plot red triangle menu contains the following options:
Hide to Deemphasize
Hides or dims all non-selected values of the Label, System ID variable when at least one value is selected.
Show Markers
Shows or hides the data markers in the plot.
Show Connected Observations
Shows or hides lines that connect the data markers for each set of repeated measures.
Show Initial Fitted Curves
Shows or hides the initial fitted curves in the plot.
