In the Evaluate Design report, the Design section shows the design runs for the factors that you have specified in the launch window. You can easily view the design as you explore its properties in the Design Evaluation section.
In the Evaluate Design platform, design evaluation is based on your design and the specifications that you make in the Model and Alias Terms sections. Several DOE Design platforms provide a Design Evaluation section: Custom, Definitive Screening, Screening, Response Surface, and Mixture with Optimal design type. Design Evaluation within these platforms is based on the design that you construct.
