Publication date: 06/21/2023
DOE Messages
obj<<Get Prediction Variances
Description
Returns a vector of the MC variances used for the FDS plot.
Example
dt = Open( "$SAMPLE_DATA/Design Experiment/Bounce Data.jmp" );
d = DOE( Evaluate Design, X( :Silica, :Sulfur, :Silane ), Y( :Stretch ) );
d << Get Prediction Variances;
obj<<Set Number of FDS Points()
Description
Enables you to specify the number of runs used to generate an FDS plot.
Example
d << Set Number of FDS Points( 20000 );
