Use the Oneway platform to produce a cumulative distribution function (CDF) plot.
1. Select Help > Sample Data Folder and open Analgesics.jmp.
3. Select pain and click Y, Response.
4. Select drug and click X, Factor.
5. Click OK.
6. Click the Oneway Analysis red triangle menu and select CDF Plot.
Figure 6.32 Example of a CDF Plot
The CDF plot has a curve for each level of the X variable.
