The Explore Patterns platform enables you to detect unusual or unexpected patterns in your data. Although some patterns occur by chance or some innocent mechanism, they might indicate data that has been falsified or tampered with. The Explore Patterns platform is most useful when the values are precise so that matches and patterns are less likely to happen by coincidence. The Explore Patterns platform is also designed to handle large data tables efficiently.
Figure 23.1 Example of Explore Patterns Report
