The Factor Analysis red triangle menu contains the following options:
Eigenvalues
Shows or hides a table of the eigenvalues of the original correlation, covariance, or unscaled and uncentered matrix. The table includes the percent of the total variance represented by each eigenvalue, a bar chart illustrating the percent contribution, and the cumulative percent contributed by each successive eigenvalue. The number of eigenvalues that are greater than or equal to 1.0 can be taken as a guideline of the number of factors for analysis.
Scree Plot
Shows or hides a plot of the eigenvalues versus the number of components (or factors). The plot can be used as an additional guideline to determine the number of factors that contribute to the maximum amount of variance. The point at which the plotted line levels out can be used as the number of sufficient factors for analysis.
Bartlett’s Test of Sphericity
Shows or hides the results of the Bartlett’s Test of Sphericity. This test is a homogeneity test that determines whether the eigenvalues have the same variance by calculating the Chi-square, degrees of freedom (DF), and the p-value (prob > ChiSq) for the test. See Bartlett (1937, 1954).
Kaiser-Meyer-Olkin Test
Shows or hides the results of the Kaiser-Meyer-Olkin (KMO) test. The test is an indicator of the proportion of variance that might be common variance, potentially due to underlying factors. The test statistic is calculated for each individual variable and for the set of all variables and is referred to as the Measure of Sampling Adequacy (MSA) in JMP. The following values indicate the suitability of the variables for factor analysis:
– 0.00 to 0.49 unacceptable
– 0.50 to 0.59 miserable
– 0.60 to 0.69 mediocre
– 0.70 to 0.79 middling
– 0.80 to 0.89 meritorious
– 0.90 to 1.00 marvelous
Note: The KMO test is not available if the correlation matrix is singular.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
