Using JMP > JMP Reports > The Data Filter > Filtering Modes
Publication date: 06/21/2023
Filtering Modes
In the JMP Data Filter, there are three modes of filtering: Select, Show, and Include. You can set and clear these modes using the corresponding check boxes.
Select
(Not available for the Local Data Filter.) Shows the selected rows in the data table in a highlighted state.
You can turn off the automatic selection of this option using the Data Filter Select Check preference. See also Changing the Row State in the Data Table After Making Data Filter Selections.
Show
Shows the unselected rows with the Hide icon Image shown here.
You can turn on the automatic selection of this option using the Data Filter Show Check preference. For more information about row states, see the Store Information in Row State Columns.
Include
Shows the unselected rows with the Exclude icon Image shown here.
You can turn on the automatic selection of this option using the Data Filter Include Check preference. For more information about row states, see the Store Information in Row State Columns.
There are two additional options when filtering: Auto clear and Conditional. These options are available from the red triangle menu for the Data Filter. See Red Triangle Options for the Data Filter.
