In the Fit Model launch window, when you have more than one Y and you select the Fit Separately option for Standard Least Squares, the responses are grouped in a report called Fit Group. The red triangle menu includes the following options:
Profiler
Shows all responses in a single profiler. You can view the effects of model terms on all responses simultaneously and perform multiple optimization. See Profiler.
Contour Profiler
Shows all responses in a single contour profiler. You can explore the effects of model terms on all responses simultaneously.
Surface Profiler
Shows separate surface profiler reports for each response.
Arrange in Rows
Rearranges the reports for the platform analyses in a specified number of rows. This would be used mostly to arrange reports so that more reports fit in a window or on the page of output.
Order by Goodness of Fit
Sorts the reports by significance of fit (RSquare). This option is available only for platforms that surface the RSquare to the platform level. For example, if you generate hundreds of Oneway analyses from one launch window, they appear in a FitGroup and you can sort them so that the strongest relationships appear first.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
