Using JMP > JMP Reports > Semantic Formatting > Format a Column in a Report Table
Publication date: 06/21/2023
To format an entire column with the formats that you created in the previous section, complete the following steps:
1. Right-click in the table that you want to reformat a row in and select Format Column. The Column Numeric Format window opens.
2. Listed in the Matched Semantic Formats section is the format that you created in the previous section. Select it and click Edit. The Edit Semantic Format window opens.
3. Deselect the Row Label option and click OK.
4. Click OK.
The report window is updated with the custom format
