Using JMP > Import Your Data > Import Data from an OSIsoft PI Server > Import Plot Data from an OSIsoft PI Server
Publication date: 06/21/2023
Plot data is optimized for graphing the results. The following field is specific to plot data:
No. of intervals
Specify the number of intervals to fetch. You can have up to five values per interval. This value indicates how much data will be imported.
Click Import to start importing plot data from the PI Server.
