Discovering JMP > Special Features > Integrate JMP and SAS
Publication date: 06/21/2023
Using JMP, you can interact with SAS in many ways:
Write or create SAS code in JMP.
Submit SAS code and view the results in JMP.
Connect to a SAS Metadata Server or a SAS Server on a remote machine.
Connect to SAS on your local machine.
Open and browse SAS data sets.
Retrieve and view data sets generated by SAS.
For more information about integrating JMP and SAS, see Import Data from SAS in Using JMP.
Note: You must have access to SAS, either on your local machine or on a server, to use SAS through JMP.
