Genetics
Genetics provides two methods in JMP to help you analyze your genetic data and use that data to simulate a breeding program to predict the optimum genetic crosses to make.
• The Marker Statistics platform provides a convenient method for exploring several properties of all the biallelic markers in a data set, for the purpose of quality control (QC) and possibly selecting markers to be removed from the analysis See Marker Statistics.
• The Marker Simulation platform simulates the progeny from a specified set of crosses using biallelic markers and predictor formulas (predictive models generated using the Response Screening** platform) saved in your data table. This process enables you to test various crosses to estimate which crosses will generate progeny with the desired combinations of traits. See Marker Simulation.
