Welcome to JMP > Learn about JMP > JMP Documentation Library
Publication date: 06/21/2023
The Help system content is also available in one PDF file called JMP Documentation Library. Select Help > JMP Documentation Library to open the file. You can also download the Documentation PDF Files add-in if you prefer searching individual PDF files of each document in the JMP library. Download the available add-ins from https://community.jmp.com.
The following table describes the purpose and content of each document in the JMP library.
Document Title
Document Purpose
Document Content
Discovering JMP
If you are not familiar with JMP, start here.
Introduces you to JMP and gets you started creating and analyzing data. Also learn how to share your results.
Using JMP
Learn about JMP data tables and how to perform basic operations.
Covers general JMP concepts and features that span across all of JMP, including importing data, modifying columns properties, sorting data, and connecting to SAS.
Basic Analysis
Perform basic analysis using this document.
Describes these Analyze menu platforms:
Distribution
Fit Y by X
Tabulate
Text Explorer
Covers how to perform bivariate, one-way ANOVA, and contingency analyses through Analyze > Fit Y by X. How to approximate sampling distributions using bootstrapping and how to perform parametric resampling with the Simulate platform are also included.
Essential Graphing
Find the ideal graph for your data.
Describes these Graph menu platforms:
Graph Builder
Scatterplot 3D
Contour Plot
Bubble Plot
Parallel Plot
Cell Plot
Scatterplot Matrix
Ternary Plot
Treemap
Chart
Overlay Plot
The book also covers how to create background and custom maps.
Profilers
Learn how to use interactive profiling tools, which enable you to view cross-sections of any response surface.
Covers all profilers listed in the Graph menu. Analyzing noise factors is included along with running simulations using random inputs.
Design of Experiments Guide
Learn how to design experiments and determine appropriate sample sizes.
Covers all topics in the DOE menu.
Fitting Linear Models
Learn about Fit Model platform and many of its personalities.
Describes these personalities, all available within the Analyze menu Fit Model platform:
Standard Least Squares
Stepwise
Generalized Regression
Mixed Model
Generalized Linear Mixed Model
MANOVA
Loglinear Variance
Nominal Logistic
Ordinal Logistic
Generalized Linear Model
Learn about additional modeling techniques.
Describes these Analyze > Predictive Modeling menu platforms:
Neural
Partition
Bootstrap Forest
Boosted Tree
K Nearest Neighbors
Naive Bayes
Support Vector Machines
Model Comparison
Model Screening
Make Validation Column
Formula Depot
Describes these Analyze > Specialized Modeling menu platforms:
Fit Curve
Nonlinear
Functional Data Explorer
Gaussian Process
Time Series
Matched Pairs
Describes these Analyze > Screening menu platforms:
Explore Outliers
Explore Missing Values
Explore Patterns
Response Screening
Predictor Screening
Association Analysis
Process History Explorer
Multivariate Methods
Read about techniques for analyzing several variables simultaneously.
Describes these Analyze > Multivariate Methods menu platforms:
Multivariate
Principal Components
Discriminant
Partial Least Squares
Multiple Correspondence Analysis
Structural Equation Models
Factor Analysis
Multidimensional Scaling
Multivariate Embedding
Item Analysis
Describes these Analyze > Clustering menu platforms:
Hierarchical Cluster
K Means Cluster
Normal Mixtures
Latent Class Analysis
Cluster Variables
Quality and Process Methods
Read about tools for evaluating and improving processes.
Describes these Analyze > Quality and Process menu platforms:
Control Chart Builder and individual control charts
Measurement Systems Analysis (EMP and Type 1 Gauge)
Variability / Attribute Gauge Charts
Process Screening
Process Capability
Model Driven Multivariate Control Chart
Legacy Control Charts
Pareto Plot
Diagram
Manage Spec Limits
OC Curves
Learn to evaluate and improve reliability in a product or system and analyze survival data for people and products.
Describes these Analyze > Reliability and Survival menu platforms:
Life Distribution
Fit Life by X
Cumulative Damage
Recurrence Analysis
Degradation
Repeated Measures Degradation
Destructive Degradation
Reliability Forecast
Reliability Growth
Reliability Block Diagram
Repairable Systems Simulation
Survival
Fit Parametric Survival
Fit Proportional Hazards
Consumer Research
Learn about methods for studying consumer preferences and using that insight to create better products and services.
Describes these Analyze > Consumer Research menu platforms:
Categorical
Choice
MaxDiff
Uplift
Multiple Factor Analysis
Genetics
Learn about methods that are available in JMP to help you analyze your genetic data and use that data to simulate a breeding program to predict the optimum genetic crosses to make.
Describes these Analyze > Genetics menu platforms:
Marker Statistics
Marker Simulation
Scripting Guide
Learn about taking advantage of the powerful JMP Scripting Language (JSL).
Covers a variety of topics, such as writing and debugging scripts, manipulating data tables, constructing display boxes, and creating JMP applications.
JSL Syntax Reference
Read about many JSL functions on functions and their arguments, and messages that you send to objects and display boxes.
Includes syntax, examples, and notes for JSL commands.
