Scripting Guide > Extending JMP > Work with SAS > Make a SAS DATA Step
Publication date: 06/21/2023
Sending Make SAS Data Step to a JMP data table returns the text for a SAS DATA Step that can re-create the data table in SAS. For example,
dt << Make SAS Data Step
prints a DATA Step to the log that can be used in the SAS Program Editor.
Sending Make SAS Data Step Window produces this code in a window with a .SAS suffix, so that it can be easily sent to SAS.
