The Mixed Model personality of the Fit Model platform is available only in JMP Pro.
The Mixed Model personality fits a wide variety of linear models for continuous responses with complex covariance structures. These models include random coefficients, repeated measures, spatial data, and data with multiple correlated responses. Use the Mixed Model personality to specify linear mixed models and their covariance structures conveniently using an intuitive interface, and to fit these models using maximum likelihood methods.
The modeling results are supported by interactive visualization tools such as profilers, surface plots, and contour plots. You can use these tools to complement your understanding of the model.
Figure 8.1 Marginal Model Profiler for a Split Plot Experiment
