Publication date: 06/21/2023
Mixtures and Constraints
The ternary plot uses the Mixture column property to shade the portion of the graph that is out of bounds. The ternary plot recognizes the mixture sum, mixture bounds, and general linear constraints. For information about setting the Mixture column property in the Column Info window, see Mixture in Using JMP.
Related Information
Example of a Ternary Plot with Mixture Constraints
