Oneway Analysis Reports
The Oneway platform enables you to create visualizations, run hypothesis tests, and fit models to explore the relationship between a categorical X variable and a continuous Y variable. This section contains information about the reports that are generated for specific analysis options.
• Quantiles Report
• Means/Anova/Pooled t Report
• Means and Std Deviations Report
• t Test Report
• Analysis of Means Reports
• Means Comparisons Reports
• Nonparametric Test Reports
• Nonparametric Multiple Comparisons Reports
• Unequal Variances Reports
• Equivalence Test Reports
• Robust Fit Reports
• Power Reports
• Matching Column Report
