Basic Analysis > Oneway Analysis > Overview of Oneway Platform
Publication date: 06/21/2023
The Oneway platform enables you to quickly visualize the distribution of a continuous Y variable across two or more levels of a categorical X variable. You can run analysis of variance (ANOVA) models, t tests, analysis of means (ANOM), equivalence tests, nonparametric tests, exact tests, or multiple comparisons to evaluate differences in means or variances across the levels of the X variable. Many tests add visualization tools to the Oneway plot in the report. In addition, there are options to use density and cumulative distribution function (CDF) plots to visualize the distribution of your response across the levels of the X variable.
Tests are grouped together in the Oneway red triangle menu according to the type of test. JMP enables you to explore many types of statistical tests. The best choice of test depends on the study design, data collection, data distributions, and the hypothesis of interest.
See the following sections for details about test reports:
Quantiles Report
Means/Anova/Pooled t Report
Means and Std Deviations Report
t Test Report
Analysis of Means Reports
Means Comparisons Reports
Nonparametric Test Reports
Nonparametric Multiple Comparisons Reports
Unequal Variances Reports
Equivalence Test Reports
Robust Fit Reports
Power Reports
Matching Column Report
