In the Partial Least Squares red triangle menu, you can use the following options before clicking Go in the Model Launch Control Panel:
Set Random Seed
Sets the seed for the randomization process used for KFold and Holdback validation. This is useful if you want to reproduce an analysis. Set the seed to a positive value, save the script, and the seed is automatically saved in the script. Running the script always produces the same cross validation analysis. This option does not appear when Validation Method is set to None, or when a validation column is used.
SVD
Shows a submenu that enables you to choose between a fast or classical implementation of the SVD algorithm in the model fitting algorithm. The default is Fast SVD.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
