Publication date: 06/21/2023
Probability Functions
In the JMP Formula Editor, you can build formulas that calculate probabilities and quantiles for statistical distributions including the beta, Chi-square, F, gamma, normal, Student’s t, and Weibull distributions. See Probability Functions in the JSL Syntax Reference for more information about distribution parameterizations and function arguments.
Beta Density
For information about the syntax for the Beta Density function, see Probability Functions in the JSL Syntax Reference.
Beta Distribution
For information about the syntax for the Beta Distribution function, see Probability Functions in the JSL Syntax Reference.
Beta Quantile
For information about the syntax for the Beta Quantile function, see Probability Functions in the JSL Syntax Reference.
Cauchy Density
For information about the syntax for the Cauchy Density function, see Probability Functions in the JSL Syntax Reference.
Cauchy Distribution
For information about the syntax for the Cauchy Distribution function, see Probability Functions in the JSL Syntax Reference.
Cauchy Quantile
For information about the syntax for the Cauchy Quantile function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Density
For information about the syntax for the ChiSquare Density function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Distribution
For information about the syntax for the ChiSquare Distribution function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Log CDistribution
For information about the syntax for the ChiSquare Log CDistribution function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Log Density
For information about the syntax for the ChiSquare Log Density function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Log Distribution
For information about the syntax for the ChiSquare Log Distribution function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Noncentrality
For information about the syntax for the ChiSquare Noncentrality function, see Probability Functions in the JSL Syntax Reference.
ChiSquare Quantile
For information about the syntax for the ChiSquare Quantile function, see Probability Functions in the JSL Syntax Reference.
Dunnett P Value
For information about the syntax for the Dunnett P Value function, see Probability Functions in the JSL Syntax Reference.
Dunnett Quantile
For information about the syntax for the Dunnett Quantile function, see Probability Functions in the JSL Syntax Reference.
Exp Density
For information about the syntax for the Exp Density function, see Probability Functions in the JSL Syntax Reference.
Exp Distribution
For information about the syntax for the Exp Distribution function, see Probability Functions in the JSL Syntax Reference.
Exp Quantile
For information about the syntax for the Exp Quantile function, see Probability Functions in the JSL Syntax Reference.
F Density
For information about the syntax for the F Density function, see Probability Functions in the JSL Syntax Reference.
F Distribution
For information about the syntax for the F Distribution function, see Probability Functions in the JSL Syntax Reference.
F Log CDistribution
For information about the syntax for the F Log CDistribution function, see Probability Functions in the JSL Syntax Reference.
F Log Density
For information about the syntax for the F Log Density function, see Probability Functions in the JSL Syntax Reference.
F Log Distribution
For information about the syntax for the F Log Distribution function, see Probability Functions in the JSL Syntax Reference.
F Noncentrality
For information about the syntax for the F Noncentrality function, see Probability Functions in the JSL Syntax Reference.
F Power
For information about the syntax for the F Power function, see Probability Functions in the JSL Syntax Reference.
F Quantile
For information about the syntax for the F Quantile function, see Probability Functions in the JSL Syntax Reference.
F Sample Size
For information about the syntax for the F Sample Size function, see Probability Functions in the JSL Syntax Reference.
Frechet Density
For information about the syntax for the Frechet Density function, see Probability Functions in the JSL Syntax Reference.
Frechet Distribution
For information about the syntax for the Frechet Distribution function, see Probability Functions in the JSL Syntax Reference.
Frechet Quantile
For information about the syntax for the Frechet Quantile function, see Probability Functions in the JSL Syntax Reference.
Gamma Density
For information about the syntax for the Gamma Density function, see Probability Functions in the JSL Syntax Reference.
Gamma Distribution
For information about the syntax for the Gamma Distribution function, see Probability Functions in the JSL Syntax Reference.
Gamma Log CDistribution
For information about the syntax for the Gamma Log CDistribution function, see Probability Functions in the JSL Syntax Reference.
Gamma Log Density
For information about the syntax for the Gamma Log Density function, see Probability Functions in the JSL Syntax Reference.
Gamma Log Distribution
For information about the syntax for the Gamma Log Distribution function, see Probability Functions in the JSL Syntax Reference.
Gamma Quantile
For information about the syntax for the Gamma Quantile function, see Probability Functions in the JSL Syntax Reference.
GenGamma Density
For information about the syntax for the GenGamma Density function, see Probability Functions in the JSL Syntax Reference.
GenGamma Distribution
For information about the syntax for the GenGamma Distribution function, see Probability Functions in the JSL Syntax Reference.
GenGamma Quantile
For information about the syntax for the GenGamma Quantile function, see Probability Functions in the JSL Syntax Reference.
GLog Density
For information about the syntax for the GLog Density function, see Probability Functions in the JSL Syntax Reference.
GLog Distribution
For information about the syntax for the GLog Distribution function, see Probability Functions in the JSL Syntax Reference.
GLog Quantile
For information about the syntax for the GLog Quantile function, see Probability Functions in the JSL Syntax Reference.
Johnson Sb Density
For information about the syntax for the Johnson Sb Density function, see Probability Functions in the JSL Syntax Reference.
Johnson Sb Distribution
For information about the syntax for the Johnson Sb Distribution function, see Probability Functions in the JSL Syntax Reference.
Johnson Sb Quantile
For information about the syntax for the Johnson Sb Quantile function, see Probability Functions in the JSL Syntax Reference.
Johnson Sl Density
For information about the syntax for the Johnson Sl Density function, see Probability Functions in the JSL Syntax Reference.
Johnson Sl Distribution
For information about the syntax for the Johnson Sl Distribution function, see Probability Functions in the JSL Syntax Reference.
Johnson Sl Quantile
For information about the syntax for the Johnson Sl Quantile function, see Probability Functions in the JSL Syntax Reference.
Johnson Su Density
For information about the syntax for the Johnson Su Density function, see Probability Functions in the JSL Syntax Reference.
Johnson Su Distribution
For information about the syntax for the Johnson Su Distribution function, see Probability Functions in the JSL Syntax Reference.
Johnson Su Quantile
For information about the syntax for the Johnson Su Quantile function, see Probability Functions in the JSL Syntax Reference.
LEV Density
For information about the syntax for the Largest Extreme Value (LEV) Density function, see Probability Functions in the JSL Syntax Reference.
LEV Distribution
For information about the syntax for the Largest Extreme Value (LEV) Distribution function, see Probability Functions in the JSL Syntax Reference.
LEV Quantile
For information about the syntax for the Largest Extreme Value (LEV) Quantile function, see Probability Functions in the JSL Syntax Reference.
LogGenGamma Density
For information about the syntax for the LogGenGamma Density function, see Probability Functions in the JSL Syntax Reference.
LogGenGamma Distribution
For information about the syntax for the LogGenGamma Distribution function, see Probability Functions in the JSL Syntax Reference.
LogGenGammaQuantile
For information about the syntax for the LogGenGamma Quantile function, see Probability Functions in the JSL Syntax Reference.
Logistic Density
For information about the syntax for the Logistic Density function, see Probability Functions in the JSL Syntax Reference.
Logistic Distribution
For information about the syntax for the Logistic Distribution function, see Probability Functions in the JSL Syntax Reference.
Logistic Quantile
For information about the syntax for the Logistic Quantile function, see Probability Functions in the JSL Syntax Reference.
Loglogistic Density
For information about the syntax for the Loglogistic Density function, see Probability Functions in the JSL Syntax Reference.
Loglogistic Distribution
For information about the syntax for the Loglogistic Distribution function, see Probability Functions in the JSL Syntax Reference.
Loglogistic Quantile
For information about the syntax for the Loglogistic Quantile function, see Probability Functions in the JSL Syntax Reference.
Lognormal Density
For information about the syntax for the Lognormal Density function, see Probability Functions in the JSL Syntax Reference.
Lognormal Distribution
For information about the syntax for the Lognormal Distribution function, see Probability Functions in the JSL Syntax Reference.
Lognormal Quantile
For information about the syntax for the Lognormal Quantile function, see Probability Functions in the JSL Syntax Reference.
Normal Biv Distribution
For information about the syntax for the Normal Biv Distribution function, see Probability Functions in the JSL Syntax Reference.
Normal Density
For information about the syntax for the Normal Density function, see Probability Functions in the JSL Syntax Reference.
Normal Distribution
For information about the syntax for the Normal Distribution function, see Probability Functions in the JSL Syntax Reference.
Normal Log CDistribution
For information about the syntax for the Normal Log CDistribution function, see Probability Functions in the JSL Syntax Reference.
Normal Log Density
For information about the syntax for the Normal Log Density function, see Probability Functions in the JSL Syntax Reference.
Normal Log Distribution
For information about the syntax for the Normal Log Distribution function, see Probability Functions in the JSL Syntax Reference.
Normal Mixture Density
For information about the syntax for the Normal Mixture Density function, see Probability Functions in the JSL Syntax Reference.
Normal Mixture Distribution
For information about the syntax for the Normal Mixture Distribution function, see Probability Functions in the JSL Syntax Reference.
Normal Mixture Quantile
For information about the syntax for the Normal Mixture Quantile function, see Probability Functions in the JSL Syntax Reference.
Normal Quantile
For information about the syntax for the Normal Quantile function, see Probability Functions in the JSL Syntax Reference.
SEV Density
For information about the syntax for the Smallest Extreme Value (SEV) Density function, see Probability Functions in the JSL Syntax Reference.
SEV Distribution
For information about the syntax for the Smallest Extreme Value (SEV) Distribution function, see Probability Functions in the JSL Syntax Reference.
SEV Quantile
For information about the syntax for the Smallest Extreme Value (SEV) Quantile function, see Probability Functions in the JSL Syntax Reference.
SHASH Density
For information about the syntax for the SHASH Density function, see Probability Functions in the JSL Syntax Reference.
SHASH Distribution
For information about the syntax for the SHASH Distribution function, see Probability Functions in the JSL Syntax Reference.
SHASH Quantile
For information about the syntax for the SHASH Quantile function, see Probability Functions in the JSL Syntax Reference.
t Density
For information about the syntax for the t Density function, see Probability Functions in the JSL Syntax Reference.
t Distribution
For information about the syntax for the t Distribution function, see Probability Functions in the JSL Syntax Reference.
t Log CDistribution
For information about the syntax for the t Log CDistribution function, see Probability Functions in the JSL Syntax Reference.
t Log Density
For information about the syntax for the t Log Density function, see Probability Functions in the JSL Syntax Reference.
t Log Distribution
For information about the syntax for the t Log Distribution function, see Probability Functions in the JSL Syntax Reference.
t Noncentrality
For information about the syntax for the t Noncentrality function, see Probability Functions in the JSL Syntax Reference.
t Quantile
For information about the syntax for the t Quantile function, see Probability Functions in the JSL Syntax Reference.
Tukey HSD P Value
For information about the syntax for the Tukey HSD P Value function, see Probability Functions in the JSL Syntax Reference.
Tukey HSD Quantile
For information about the syntax for the Tukey HSD Quantile function, see Probability Functions in the JSL Syntax Reference.
Weibull Density
For information about the syntax for the Weibull Density function, see Probability Functions in the JSL Syntax Reference.
Weibull Distribution
For information about the syntax for the Weibull Distribution function, see Probability Functions in the JSL Syntax Reference.
Weibull Quantile
For information about the syntax for the Weibull Quantile function, see Probability Functions in the JSL Syntax Reference.
