Publication date: 06/21/2023
SAS Results Messages
results<<Delete All Result Files()
Description
Deletes all files created by the SAS Submit or Stored Process execution. Note that any result files that are still in use are not deleted.
Returns
1 if the deletion was successful; 0 if some of the files could not be deleted.
results<<Get Directory()
Description
Gets the directory where the results generated by the stored process or SAS submit are located.
Returns
A quoted string.
results<<Get Log()
Description
Get the SAS Log from the execution of the stored process or SAS submit.
Returns
A quoted string.
results<<Get Main Result File Name(<Fullpath(Boolean)>)
Description
Gets the full path of the main result file generated by the stored process or SAS submit.
Returns
A quoted string.
Optional Named Argument
Fullpath(Boolean)
If true, the main result filename is returned as a full path. The default value is false.
results<<Get Output()
Description
Gets the SAS Listing output from the execution of the stored process or SAS submit.
Returns
A quoted string.
results<<Get Output Datasets()
Description
Get a list of output data set generated by the SAS Submit that created this SAS Results object.
Returns
A list of data set names in the form “libname.membername”.
results<<Get Result File Info(<Mimetype(mime-type)>, <Fullpath(Boolean)>)
Description
Get information about result files that were generated by the execution of the stored process or SAS submit.
Returns
List of two lists of quoted strings. The first list is filenames, and the second list is the MIME-type of the corresponding file from the first list.
Optional Arguments
Mimetype(mime_type)
Restricts the set of files for which information is returned to only those files with the specified quoted MIME-type. If not specified, information about all generated files is returned.
Fullpath(Boolean)
If true, the filename returned for each result file is returned as a full path; if false, only the name of the file is returned. The default value is false.
results<<Make JMP Report()
Description
Parses the ODS XML results and creates a JMP report.
Returns
The display box for the report.
results<<Open All Results()
Description
Opens all results generated by the execution of the stored process or SAS submit.
Returns
Void.
results<<Open Result File(filename, <Run Script(Boolean)>)
Description
Attempts to open the result file with the given name.
Returns
JMP Data Table if one was opened.
Required Argument
filename
Specifies the quoted name of the file from the generated results to open. filename should just be the name of the file, not the full path. If filename is a filename with no extension, both JMP data tables and JSL scripts in the results are searched for a match, and if both exist, both are opened.
Optional Argument
Run Script(Boolean)
If true, and if filename is a JSL script, the script is executed. If false, filename is just opened, even if it is a JSL script.
results<<Run Script(filename)
Description
Looks for the JSL file in the results with the given filename and runs it if it finds it.
Returns
Void.
Argument
"filename"
Specifies the quoted name of the JSL file from the generated results to open. The filename argument should just be the name of the file, not the full path, and it does not need to include the .jsl extension.
