Publication date: 06/21/2023
Save the Diagram as a Script
Saving the Cause and Effect Diagram as a script is a good approach if you have other processes that need to update the data table. If you created the diagram from a data table, a simple script appears that relaunches against the data table with no customization. If you created the diagram without using a data table (or from a journal), a more complex script appears that contains all the commands needed to add and customize each area of the diagram.
To save the diagram as a script, perform the following steps:
1. Click the Cause and Effect Diagram red triangle and select Save Script > To Script Window.
2. Save the new script.
