In the Multiple Correspondence Analysis platform, this option shows the table of singular values.
Singular Value
Shows the singular values in the singular value decomposition of the contingency table or Burt table. For the formula, see Statistical Details for the Details Report.
Inertia
Lists the square of the singular values, reflecting the relative variation accounted for in the canonical dimensions.
ChiSquare
Lists the portion of the overall Chi-square for the Burt or contingency table represented by the dimension.
Percent
Portion of inertia with respect to the total inertia.
Cumulative Percent
Shows the cumulative portion of inertia. If the first two singular values capture the bulk of the inertia, then the 2-D correspondence analysis plot is sufficient to show the relationships in the table.
