Quality and Process Methods > Control Chart Builder > Statistical Details for Control Chart Builder
Publication date: 06/21/2023
This section contains statistical details for Control Chart Builder.
Statistical Details for XBar and R Charts
Statistical Details for XBar and S Charts
Statistical Details for Individual Measurement and Moving Range Charts
Statistical Details for P, NP, and Laney P Charts
Statistical Details for U, C, and Laney U Charts
Statistical Details for Levey-Jennings Charts
Statistical Details for G Charts
Statistical Details for T Charts
Statistical Details for Three Way Control Charts
Notes:
Control limits are calculated using a sigma multiplier, K, which is set to 3 by default. To change the default value of K, use the K Sigma option in the red triangle menu or the K Sigma preference in File > Preferences > Platforms > Control Chart Builder.
For sample sizes up to n = 50, JMP uses control chart constants d2(n) and d3(n) that are defined in Table 2 of Harter (1960). For samples with a sample size greater than 50, JMP uses the control chart constant values for sample size 50 in both the sigma and control limit calculations.
