Publication date: 06/21/2023
Statistical Details for Odds Ratios
This section contains details for the odds ratios computed in the Fit Model platform.
For two response levels, the logistic regression model is specified as follows:
Equation shown here where r1 and r1 are the two response levels
Therefore, the odds are defined as follows:
Equation shown here
Note that exp(βi(Xi + 1)) = exp(βiXi) exp(βi). This shows that if Xi changes by a unit amount, the odds is multiplied by exp(βi), which we label the unit odds ratio. As Xi changes over its whole range, the odds are multiplied by exp((Xhigh - Xlow)βi), which we label the range odds ratio. For binary responses, the log odds ratio for flipped response levels involves only changing the sign of the parameter. Therefore, you might want the reciprocal of the reported value to focus on the last response level instead of the first.
Two-level nominal effects are coded 1 and -1 for the first and second levels, so range odds ratios or their reciprocals would be of interest.
If no confidence intervals for the parameter estimates have been calculated when you select the Odds Ratio option, selecting the Odds Ratio option produces Wald-based confidence intervals for the odds ratio.
Selecting the Odds Ratio option produces profile likelihood-based confidence intervals for the odds ratios when all of the following conditions are met:
the Likelihood Ratio Tests option has been selected
the Confidence Intervals option has been selected
the number of parameters for each response is less than 8
the number of rows is less than 1000.
The method used for computing confidence intervals for the odds ratios is noted at the bottom of the Odds Ratios report.
