Basic Analysis > Text Explorer
Publication date: 06/21/2023
Text Explorer
Explore Unstructured Text in Your Data
Image shown hereMany features in this platform are available only in JMP Pro and noted with this icon.
The Text Explorer platform enables you to analyze unstructured text, such as comment fields in surveys or incident reports. Interact with the text data by using tools to combine similar terms, recode misspecified terms, and understand the underlying patterns in your textual data.
Image shown hereThe JMP Pro version of the platform contains analysis tools that use singular value decomposition (SVD) to group similar documents into topics. You can cluster text documents or cluster terms that are in a collection of documents. You can also cluster documents using latent class analysis.
Image shown hereThe JMP Pro version of the platform also contains tools for identifying important terms and sentiments in your documents. Term selection enables you to identify the terms that best explain different responses. Sentiment analysis enables you to identify sentiment terms in document using lexical analysis and scores documents for positive, negative, and overall sentiment. The Sentiment Analysis feature includes basic natural language processing (NLP) support.
Figure 12.1 SVD Plots in Text Explorer
Contents
Overview of the Text Explorer Platform
Text Processing Steps
Example of the Text Explorer Platform
Launch the Text Explorer Platform
Customize Regex in the Regular Expression Editor
The Text Explorer Report
Summary Counts Report
Term and Phrase Lists
Text Explorer Platform Options
Text Preparation Options
Text Analysis Options
Save Options
Report Options in Text Explorer
Latent Class Analysis
Latent Semantic Analysis (SVD)
SVD Report
SVD Report Options
Topic Analysis
Topic Analysis Report
Topic Analysis Report Options
Discriminant Analysis
Discriminant Analysis Report
Discriminant Analysis Report Options
Term Selection
Term Selection Settings
Term Selection Report
Term Selection Report Options
Sentiment Analysis
Sentiment Analysis Report
Sentiment Analysis Report Options
Additional Example of the Text Explorer Platform
