The DOE platforms are structured as a series of steps that guide you through the workflow of designing experiments. Once you complete each step, you click Continue to move to the next step. The elements described in this section are common to nine of the design of experiments platforms. These are the platforms that are addressed in this section:
• Custom Design
• Definitive Screening Design
• Screening Design
• Response Surface Design
• Full Factorial Design
• Mixture Design
• Covering Array
• Space Filling Design
• Taguchi Arrays
Three special-purpose platforms differ substantially: Choice Designs, Accelerated Life Test Design, and Nonlinear Design. These three platforms are not addressed in this section.
This section describes the steps in the DOE workflow. It also discusses their implementation in the various design platforms.
