Publication date: 06/21/2023
The Manova Fit Options
The Manova Fit red triangle menu contains the following options:
Save Discrim
Performs a discriminant analysis and saves the results to the data table. See Discriminant Analysis in Multivariate Response Models.
Save Predicted
Saves the predicted responses to the data table.
Save Residuals
Saves the residuals to the data table.
Model Dialog
Shows the completed launch window for the current analysis.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
