The Observed Data report appears by default. If the Parallel Systems data format is specified in the launch window, the Model Descriptions and Feasibilities report also appears by default.
In the Reliability Growth platform, the Model Description and Feasibilities report lists the name and descriptions of the parallel systems models. It also contains a column that shows if a model is available for the current data. If a model is listed as not available, the reason is reported in the right-most column of this table.
