Predictive and Specialized Modeling > Time Series Forecast > The Time Series Forecast Report
Publication date: 06/21/2023
The Time Series Forecast report contains summary tables based on the variables specified in the launch window. A summary table of the time series by group is always provided. If a Time column is specified, the report also contains a summary of the time pattern and a summary table of the time by group. The report also contains a Modeling Specifications section that enables you to fit models to each time series.
Analysis of Time Pattern
Group Summary of Time
