Quality and Process Methods > Variability Gauge Charts > Variability Gauge Platform Options
Publication date: 06/21/2023
The Variability Gauge red triangle menu contains the following options:
Save
Shows a submenu of the following options:
Save Metadata as Column Properties
(Not available if a By variable is specified in the launch window.) Saves the metadata as column properties in the original data table. This includes the measurement sigma, which is saved in the Process Screening column property. The measurement sigma is the square root of the total of all variance components subtracted by the part variance.
Save All Metadata to Table
Saves a new data table that contains the metadata for each column. This includes the measurement sigma, which is used in the Process Screening platform. The measurement sigma is the square root of the total of all variance components subtracted by the part variance. If there is a By variable, a table is saved for each level of the By variable and the table name includes the level.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
