Publication date: 04/21/2023
Assignment Functions
JSL also provides operators for in-place arithmetic, or assignment operators. These operations are all done in place, meaning that the result of the operation is assigned to the first argument. The most basic assignment operator is the = operator (or the equivalent function Assign). For example, if a is 3 and you do a+=4, then a becomes 7.
The first argument to an assignment function must be something capable of being assigned (an L-value). You cannot do something like 3+=4, because 3 is just a value and cannot be reassigned. However, you can do something like a+=4, because a is a variable whose value you can set.
Add To(a, b)
a+=b
Description
Adds a and b and places the sum into a.
Returns
The sum.
Arguments
a
Must be a variable.
b
Can be a variable, a list, a number, or a matrix.
Notes
The first argument must be a variable, because its value must be able to accept a value change. A number as the first argument produces an error.
For Add To(): Only two arguments are permitted. If one or no argument is specified, Add To() returns a missing value. Any arguments after the first two are ignored.
For a+=b: More than two arguments can be strung together. JMP evaluates pairs from right to left, and each sum is placed in the left-hand variable. All arguments except the last must be a variable.
Example
a+=b+=c
JMP adds b and c and places the sum into b. Then JMP adds a and b and places the sum into a.
See Also
List Operators and Functions in the Scripting Guide
Assign(a, b)
a=b
Description
Places the value of b into a.
Returns
The new value of a.
Arguments
a
Must be a variable.
b
Can be a variable, number, or matrix.
Notes
a must be a variable, because it must be able to accept a value change. A number as the first argument produces an error. If b is some sort of expression, it’s evaluated first and the result is placed into a.
See Also
Divide To(a, b)
a/=b
Description
Divides a by b and places the result into a.
Returns
The quotient.
Arguments
a
Must be a variable.
b
See Also
Multiply To(a, b)
a*=b
Description
Multiplies a and b and places the product into a.
Returns
The product.
Arguments
a
Must be a variable.
b
Notes
For Multiply To(): Only two arguments are permitted. If one or no argument is specified, Multiply To() returns a missing value. Any arguments after the first two are ignored.
For a*=b: More than two arguments can be strung together. JMP evaluates pairs from right to left, and each product is placed in the left-hand variable. All arguments except the last must be a variable.
Example
a*=b*=c
JMP multiplies b and c and places the product into b. Then JMP multiplies a and b and places the product into a.
See Also
PostDecrement(a)
a--
Description
Post-decrement. Subtracts 1 from a and places the difference into a.
Returns
a-1
Argument
a
Must be a variable.
Notes
If a-- or Post Decrement(a) is inside another expression, the expression is evaluated first, and then the decrement operation is performed. This expression is mostly used for loop control.
See Also
Post Increment(a)
a++
Description
Post-increment. Adds 1 to a and places the sum into a.
Returns
a+1
Argument
a
Must be a variable.
Notes
If a++ or Post Increment(a) is inside another expression, the expression is evaluated first, and then the increment operation is performed. Mostly used for loop control.
See Also
Subtract To(a, b)
a-=b
Description
Subtracts b from a and places the difference into a.
Returns
The difference.
Arguments
a
Must be a variable.
b
Notes
For SubtractTo(): Only two arguments are permitted. If fewer than two or more than two arguments is specified, SubtractTo() returns a missing value.
For a-=b: More than two arguments can be strung together. JMP evaluates pairs from right to left, and each difference is placed in the left-hand variable. All arguments except the last must be a variable.
Example
a-=b-=c
JMP subtracts c from b and places the difference into b. Then JMP subtracts b from a and places the difference into a.
See Also
