Publication date: 04/21/2023
Cause and Effect Diagram Menu Options
The Cause and Effect Diagram red triangle menu contains options to redo the analysis and save scripts.
See Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
