Essential Graphing > Cell Plots > Cell Plot Platform Options
Publication date: 04/21/2023
The Cell Plot red triangle menu provides the following options:
Legend
Shows or hides a legend.
Arrange Plots
Specifies how many plots to put on the same row before starting the next row of plots.
This option is available only if you specify an X, Grouping variable.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
