Profilers > Profiler > Design Space Profiler > Design Space Profiler Options
Publication date: 04/21/2023
The Design Space Profiler red triangle menu contains the following options:
Show Portion for Each Response
Shows or hides a column in the table of responses that contains the in-specification portion for each response at the current lower and upper limits for the factors. If there is more than one response, this column is shown by default.
Send Midpoints to Profiler
Sends the midpoints to the Prediction Profiler and sets the factors to the midpoint values. These values are the midpoints between the current Design Space Profiler lower and upper limits for the factors.
Send Limits to Simulator
Sends the current limits for the continuous factors and a specified distribution to the Simulator. You can select a normal distribution with the limits at 2σ or 3σ or a uniform distribution. The Simulator uses the Design Space Profiler factor limits and the specified distribution to define the parameters for the random factor distribution. If you select a normal distribution, the factor limits are used to determine the mean and the standard deviation, σ. If you select a uniform distribution, the factor limits are used to determine the lower and upper values of the distribution. This option also sends the Error StdDev value for each response to the Simulator. The values are used as the standard deviation of the added random noise for the corresponding response.
If there are categorical factors, this option sends an equal probability multinomial random distribution to the simulator. Any factor levels that have been excluded in the Design Space Profiler have probabilities set to zero in the Simulator.
Note: This option launches the Simulator if it has not been launched yet.
Make and Connect Random Table
Creates a new data table that contains uniformly distributed factor settings and their corresponding simulated responses. The new data table is connected to the design space profiler and the rows that contain factors that are within the current lower and upper limits are selected.
Connect to Table
Connects the Design Space Profiler report to the specified data table. The rows that contain factors that are within the current lower and upper limits are selected in the connected table. The row selections are automatically updated as changes are made in the Design Space Profiler report.
Connect Hide Mode
(Available only after the Connect to Table option is selected.) Hides the rows in the connected data table that contain factors that are outside of the current lower and upper limits.
Save X Spec Limits
Saves the current operating limits for the factors as spec limits column properties in the original data table.
