Design of Experiments Guide > Starting Out with DOE > Example of a Designed Experiment
Publication date: 04/21/2023
The following example uses DOE to examine the strength of brewed coffee. A less complex treatment of this example using the Easy DOE platform is described in “Example of Easy DOE”.
Define the Study and Goals
Create the Design
Run the Experiment
Analyze the Data
