Publication date: 04/21/2023
Examples of HTTP Requests
The following examples communicate with the National Aeronautics and Space Administration (NASA) API. You must request a key from https://api.nasa.gov/index.html#apply-for-an-api-key and assign it to the key variable to run the scripts successfully.
Write Data to the Log
url = "http://technology.nasa.gov/api/query/patent/all";
request = New HTTP Request( URL( url ), Method( "Get" ) );
data = request << Send();
Write( data );
{"results":[["59fa04859600022b4d2e076f","LAR-TOPS-48","All-Organic Electroactive Device","NASA's Langley Research Center offers you an all-organic electroactive device system fabricated with single-wall carbon nanotube (SWCNT)....}
// JSON output written to the log
Notes:
The query string is at the end of the URL, following “?”. For example, in https://www.google.com/search?q=jmp, “q=jmp” is the query string. New HTTP Request() automatically URI-encodes key/value pairs in a query string (and FORM).
When you put an associative array in either a query string or a form, the key/value pairs get URI encoded. Spaces, ampersands, and other characters get encoded to ASCII, and the ampersand is escaped. The encoding is a “%” encoding.
The web service defines the valid key/value pairs that it accepts. Refer to the API documentation for valid key/value pairs.
For Kerberos authentication, specify the password as follows:
Password(":")
Return Data as an Associative Array and Write it to the Log
json = request << Send();
jsl_json = Parse JSON( json );
// turns JSON data into a JSL associative array
results = jsl_json["results"];
Write( results );
{{"59fa04859600022b4d2e076f", "LAR-TOPS-48", "All-Organic Electroactive Device", "NASA's Langley Research Center offers you an all-organic electroactive device system fabricated with single-wall carbon nanotube (SWCNT)....}}
// associative array
Return Data as a JMP Data Table
json = As JSON Expr( jsl_json["results"] );
dt = JSON To Data Table(
	json,
	JSON Settings(
		Stack( 0 ),
		Col(
			"/root",
			Column Name( "root" ),
			Fill( "Use Once" ),
			Type( "Pandas Values" ),
			Format( {"Best"} ),
			Modeling Type( "Continuous" )
dt << Set Name( "NASA Patents" );
Figure 14.5 Data Imported in a Data Table
Disable Certificate Revocation Checks for SSL Backends
When you use curl with Windows SSPI, curl sometimes considers certificates to be revoked.
The Verify SSL(1) message sets the CURLSSLOPT_NO_REVOKE option in a CA bundle when the message is sent to a New HTTP Request() object.
Names Default To Here( 1 );
    Url( "https://developer.mozilla.org/en-US/docs/Web/HTTP/Conditional_requests/cache1.png" ),
    Method( "GET" ),
    Verify SSL( 1 )
bytes = request << Send;
img = Open( bytes, jpg );
obj = New Window( "Mastering JMP", img );
