Predictive and Specialized Modeling > Explore Outliers > Explore Outliers Platform Options
Publication date: 04/21/2023
The Explorer Outliers red triangle menu contains the following options:
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
