Reliability and Survival Methods > Fit Life by X > Fit Life by X Platform Options
Publication date: 04/21/2023
The Fit Life by X red triangle menu contains the following options:
Fit Lognormal
Fits a lognormal distribution to the data.
Fit Weibull
Fits a Weibull distribution to the data.
Fit Loglogistic
Fits a loglogistic distribution to the data.
Fit Fréchet
Fits a Fréchet distribution to the data.
Fit Exponential
Fits an exponential distribution to the data.
Fit SEV
Fits a smallest extreme value (SEV) distribution to the data.
Fit Normal
Fits a normal distribution to the data.
Fit Logistic
Fits a logistic distribution to the data.
Fit LEV
Fits a largest extreme value (LEV) distribution to the data.
Fit All Distributions
Fits all distributions to the data.
Set Time Acceleration Use Condition
Enables you to enter a use condition value for the explanatory variable of the acceleration factor in a pop-up window.
Change Confidence Level
Enables you to enter a desired confidence level, for the plots and statistics, in a pop-up window. The default confidence level is 0.95.
Tabbed Report
Specifies the organization of the report. You can select one, both or none of the following suboptions.
Tabbed Overall Report
Organizes the overall report in tab panels for the plots, comparisons, and results sections of the overall report. This option is not selected by default.
Tabbed Individual Report
Organizes the individual reports in tab panels. This option is selected by default.
Show Surface Plot
Shows or hides the surface plot for the distribution on and off in the individual distribution results section of the report. The surface plot is shown in the Distribution, Quantile, Hazard, and Density sections for the individual distributions, and it is on by default.
Show Points
Shows or hides the data points on and off in the Nonparametric Overlay plot and in the Multiple Probability Plots. The points are shown in the plots by default. If this option is unchecked, step functions are shown instead.
Scatterplot
Shows a scatterplot of a lifetime event versus an explanatory variable.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
