Reliability and Survival Methods > Fit Proportional Hazards > Fit Proportional Hazards Platform Options
Publication date: 04/21/2023
The Proportional Hazards Fit red triangle menu contains the following options:
Likelihood Ratio Tests
Produces tests that compare the log-likelihood from the fitted model to one that removes each term from the model individually.
Wald Tests
Produces chi-square test statistics and p-values for Wald tests of whether each parameter is zero.
Likelihood Confidence Intervals
Specifies the type of confidence intervals shown in the Parameter Estimates table for each parameter. When this option is selected, a profile likelihood confidence interval appears. Otherwise, a Wald interval is shown. In the report, the interval type is noted below the Parameter Estimates table. This option is on by default when the computational time for the profile likelihood confidence intervals is not large.
Note: You can change the α level for the confidence intervals by selecting Set Alpha Level from the red triangle menu in the Fit Model launch window. The default α level is 0.05.
Hazard Ratios
Shows the hazard ratios for the effects. For continuous columns, unit hazard ratios and range hazard ratios are calculated. The Unit Hazard Ratio is Exp(estimate) and the Range Hazard Ratio is Exp[estimate*(xMaxxMin)]. The Unit Hazard Ratio shows the risk change over one unit of the regressor, and the Range Hazard Ratio shows the change over the whole range of the regressor. For categorical columns, hazard ratios are shown in separate reports for each effect. Note that for a categorical variable with k levels, only k -1 design variables, or levels, are used.
Tip: To see Reciprocal values in the Hazard Ratio report, right-click in the report and select Columns > Reciprocal.
Model Dialog
Shows the completed launch window for the current analysis.
Effect Summary
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See “Effect Summary Report” in Fitting Linear Models.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
