Fitting Linear Models > Generalized Linear Models > Generalized Linear Model Fit Report Options
Publication date: 04/21/2023
The Generalized Linear Model Fit red triangle menu contains the following options:
Custom Test
Enables you to test a custom hypothesis. For more information about custom tests, see “Custom Test”.
Contrast
Enables you to test for differences in levels within a variable. If a contrast involves a covariate, you can specify the value of the covariate at which to test the contrast. For an example of the Contrast option, see Example of Using Contrasts in a Generalized Linear Model.
Inverse Prediction
(Available only for continuous X variables.) Enables you to predict an X value, given specific values for Y and the other X variables. For more information about the Inverse Prediction option, see “Inverse Prediction”.
Covariance of Estimates
Shows or hides a covariance matrix for all the effects in a model. The estimated covariance matrix of the parameter estimator is defined as follows:
Σ = -H-1
where H is the Hessian (or second derivative) matrix evaluated using the parameter estimates on the last iteration. Note that the dispersion parameter, whether estimated or specified, is incorporated into H. Rows and columns corresponding to aliased parameters are not included in Σ.
Correlation of Estimates
Shows or hides a correlation matrix for all the effects in a model. The correlation matrix is the normalized covariance matrix. For each σij element of Σ, the corresponding element of the correlation matrix is σij/σiσj, where Equation shown here.
Profilers
Shows a submenu of the following profilers:
Profiler
Shows or hides a prediction profiler for examining prediction traces for each X variable. For more information about the prediction profiler, see “Profiler”.
Contour Profiler
Shows or hides an interactive contour profiler. For more information about the contour profiler, see Contour Profiler in Profilers.
Surface Profiler
Shows or hides a 3-D surface profiler. For more information about the surface profiler, see Surface Plot in Profilers.
Diagnostic Plots
Shows a submenu of plots of residuals, predicted values, and actual values. These plots enable you to search for outliers and determine the adequacy of your model. For more information about deviance, see Statistical Details for Model Selection and Deviance. The following plots are available:
Studentized Deviance Residuals by Predicted
Shows or hides a plot of studentized deviance residuals on the vertical axis and the predicted response values on the horizontal axis.
Studentized Pearson Residuals by Predicted
Shows or hides a plot of the studentized Pearson residuals on the vertical axis and the predicted response values on the horizontal axis.
Shows or hides a plot of the deviance residuals on the vertical axis and the predicted response values on the horizontal axis.
Shows or hides a plot of the Pearson residuals on the vertical axis and the predicted response values on the horizontal axis.
Regression Plot
(Available only when there is one continuous predictor and no more than one categorical predictor.) Shows or hides a plot of the response on the vertical axis and the continuous predictor on the horizontal axis. A regression line is shown over the points. If there is a categorical predictor in the model, each level of the categorical predictor has a separate regression line and a legend appears next to the plot.
Linear Predictor Plot
(Available only when there is one continuous predictor and no more than one categorical predictor.) Shows or hides a plot of responses transformed by the inverse link function on the vertical axis and the continuous predictor on the horizontal axis. A transformed regression line is shown over the points. If there is a categorical predictor in the model, each level of the categorical predictor has a separate transformed regression line and a legend appears next to the plot.
Save Columns
Shows a submenu of options that enable you to save certain quantities as new columns in the current data table. For more information about the residual formulas, see Residual Formulas.
Prediction Formula
Creates a formula column in the current data table that predicts the model.
Predicted Values
Creates a column in the current data table that contains the values predicted by the model.
Mean Confidence Interval
Creates columns in the current data table that contain the 95% confidence limits for the prediction equation for the model. These confidence limits reflect the variation in the parameter estimates.
Note: You can change the α level for the confidence limits in the Fit Model window by selecting Set Alpha Level from the Model Specification red triangle menu.
Save Indiv Confid Limits
Creates columns in the current data table that contain the 95% confidence limits for a given individual value for the model. These confidence limits reflect variation in the error and variation in the parameter estimates.
Deviance Residuals
Creates a column in the current data table that contains the deviance residuals.
Pearson Residuals
Creates a column in the current data table that contains the Pearson residuals.
Creates a column in the current data table that contains the studentized deviance residuals.
Creates a column in the current data table that contains the studentized Pearson residuals.
Model Dialog
Shows the completed launch window for the current analysis.
Effect Summary
Shows or hides the Effect Summary report, which enables you to interactively update the effects in the model. See “Effect Summary Report”.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
