When you hover over a visual element in a JMP graph, usually you see a basic description of the data point on a hover label.
You can customize what appears on the hover label using the following methods:
• Add Rich Text to Hover Labels Using Textlets
• Add Graphs or Images to Hover Labels Using Graphlets
• Update Names and Values in Hover Labels Using Gridlets
