Publication date: 04/21/2023
Install Python
JMP 17 is a 64-bit program, so only 64-bit Python is supported.
Python.org 3.7.x and higher is supported on Windows and macOS. On Apple silicon, you will not have full functionality until third-party packages have been updated.
Anaconda 3.7 and higher distributions are supported on Windows only.
JMP does not currently support Python virtual environments.
Add Python 3.x to PATH when installing Python on Windows. This setting is used for pip install <module>.
Notes:
Python is not distributed with JMP. Download Python from the Python web site at https://python.org.
Several Python implementations are available. Visit https://www.python.org/download/alternatives to view the alternatives.
Required Python Packages
For the JMP-to-Python interfaces to work properly, you must install certain Python packages and their prerequisites. In many Python installations, such as Anaconda, these packages are already installed. If you install Python from Python.org, also install the following packages:
numpy
https://www.numpy.org
pandas
https://pandas.pydata.org
matplotlib
https://matplotlib.org
scipy
https://www.scipy.org
sqlite3
https://www.sqlite.org
PyQt5
https://pypi.org/project/PyQt5/
Use the standard Python update tools to install these packages for your Python configuration. You must use the correct pip-tool for your installation. The pip-tool name is dependent on the what product has installed Python. The installation instructions for Python have instructions on using pip tools.
