Multivariate Methods > Item Analysis > Item Analysis Platform Options
Publication date: 04/21/2023
The Item Analysis red triangle menu contains the following options:
Number of Plots Across
Enables you to specify how many ICC plots to display in each row of plots in the Characteristic Curve report. The default is one ICC plot per row.
Save Ability Formula
Saves the ability formula to a new column in the data table. This options uses the IRT Ability() JSL function. For more information about this function, see Help > Scripting Index.
See Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
