Publication date: 04/21/2023
JMP Tutorials
You can access JMP tutorials by selecting Help > Tutorials.
If you are not familiar with JMP, start with the Beginners Tutorial. It steps you through the JMP interface and explains the basics of using JMP.
The rest of the tutorials help you with specific aspects of JMP, such as designing an experiment and comparing a sample mean to a constant.
