Predictive and Specialized Modeling > K Nearest Neighbors > K Nearest Neighbors Platform Options
Publication date: 04/21/2023
Image shown hereK Nearest Neighbors Platform Options
The K Nearest Neighbors red triangle menu contains the following options:
Save Near Neighbor Rows
Saves K columns to the data table. The columns are named RowNear <k>. For a given row, the kth column contains the row number of its kth nearest neighbor.
Caution: The row numbers in the columns RowNear <k> do not update when you reorder the rows in your data table. If you reorder the rows, the values in those columns are incorrect.
Save Near Neighbor Distances
Saves K columns to the data table. The columns are named Distance <k>. For a given row, the kth column contains the distance to that row’s kth nearest neighbor.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
