Profilers > Contour Profiler > Launch the Contour Profiler Platform
Publication date: 04/21/2023
The Contour Profiler can be accessed from the Graph menu or the red triangle menus of certain platforms.
The Contour Profiler can be accessed directly from the Graph menu. When you access the Contour Profiler in this way, the Contour Profiler launch window appears. See Profiler Launch Windows.
The Contour Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers for more information about the availability of the Contour Profiler in different platforms.
The Contour Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu. Then, select Contour Profiler from the Profiler red triangle menu.
Image shown hereThe Contour Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu and select the models to be profiled. Then, select Contour Profiler from the Profiler red triangle menu.
