Publication date: 04/21/2023
Least Squares Fit Options
In the Fit Model launch window, when you select the Fit Together option for Standard Least Squares, the responses are grouped in a report called Least Squares Fit. This is useful if you have more than one Y and no missing response values, or more than one Y with missing values. The Least Squares Fit red triangle menu includes the following options:
Profilers
Shows all responses in a single profiler. You can view the effects of model terms on all responses simultaneously and perform multiple optimization. See Factor Profiling.
Model Dialog
Shows the completed launch window for the current analysis.
Effect Summary
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See Effect Summary Report.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
