Predictive and Specialized Modeling > Make Validation Column > Make Validation Column Platform Options
Publication date: 04/21/2023
Image shown hereMake Validation Column Platform Options
The Make Validation Column red triangle menu contains the following options:
See Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Save Script
