Basic Analysis > Oneway Analysis > Oneway Analysis Reports
Publication date: 04/21/2023
The Oneway platform enables you to create visualizations, run hypothesis tests, and fit models to explore the relationship between a categorical X variable and a continuous Y variable. This section contains information about the reports that are generated for specific analysis options.
Quantiles Report
Means/Anova/Pooled t Report
Means and Std Deviations Report
t Test Report
Analysis of Means Reports
Means Comparisons Reports
Nonparametric Test Reports
Nonparametric Multiple Comparisons Reports
Unequal Variances Reports
Equivalence Test Reports
Robust Fit Reports
Power Reports
Matching Column Report
